[gdal-dev] GDAL 2.2.2 release candidate
Kurt Schwehr
schwehr at gmail.com
Mon Sep 18 08:02:35 PDT 2017
+1 on RC1
I tested the build with fink and think all of these failures are likely
just from old libs being used in the fink config on Mac OSX 10.12.
-kurt
------------ Failures ------------
Script: ogr/ogr_gft.py
TEST: ogr_gft_read ... fail
line 97: did not get expected feature count
Script: ogr/ogr_gpkg.py
TEST: ogr_gpkg_18 ... fail
line 1560: validation unexpectedly succeeded
Script: ogr/ogr_ogdi.py
TEST: ogr_ogdi_4 ... fail
line 194: cannot open dataset
Script: gcore/basic_test.py
TEST: basic_test_8 ... fail
line 173: fail
Script: gcore/tiff_write.py
TEST: tiff_write_87 ... fail (blowup)
TEST: tiff_write_126 ... fail
line 5245: fail
Script: gdrivers/jpeg.py
TEST: jpeg_1 ... fail
line 566: Checksum for band 2 in "albania.jpg" is 34296, but expected
17016.
TEST: jpeg_16 ... fail
line 580: fail
Script: gdrivers/mbtiles.py
TEST: mbtiles_2 ... fail
line 84: for band 2, cs = 14034, different from expected_cs = 19386
Script: gdrivers/mrf.py
TEST: myTestCreateCopy: 12bit_rose_extract.jpg ['COMPRESS=JPEG'] ... fail
line 626: Failed to create test file using CreateCopy method.
Can't create tmp/12bit_rose_extract.jpg.tst
Script: gdrivers/rasterlite.py
TEST: rasterlite_2 ... fail
line 116: for band 2, cs = 20083, different from expected_cs = 19843
Script: gdrivers/vrtderived.py
TEST: vrtderived_7 ... fail
line 264: fail
Script: utilities/test_gdalwarp.py
TEST: test_gdalwarp_28 ... fail
line 735: Bad checksum
Script: pyscripts/test_gdal_retile.py
TEST: test_gdal_retile_cleanup ... fail (blowup)
otool -L /sw/bin/gdalinfo
/sw/bin/gdalinfo:
/sw/lib/libgdal.20.dylib (compatibility version 24.0.0, current version
24.1.0)
/sw/lib/libproj.9.dylib (compatibility version 11.0.0, current version
11.0.0)
/sw/lib/libjson-c.2.dylib (compatibility version 3.0.0, current version
3.2.0)
/sw/lib/libfreexl.1.dylib (compatibility version 3.0.0, current version
3.0.0)
/sw/opt/libgeos3.5.0/lib/libgeos_c.1.dylib (compatibility version 11.0.0,
current version 11.0.0)
/sw/lib/webp7/libwebp.7.dylib (compatibility version 8.0.0, current version
8.0.0)
/sw/lib/libsqlite3.0.dylib (compatibility version 9.0.0, current version
9.6.0)
/sw/lib/libodbc.2.dylib (compatibility version 3.0.0, current version 3.0.0)
/sw/lib/libodbcinst.2.dylib (compatibility version 3.0.0, current version
3.0.0)
/sw/lib/libexpat.1.dylib (compatibility version 8.0.0, current version
8.5.0)
/sw/lib/libxerces-c-3.1.dylib (compatibility version 3.1.1, current version
3.1.1)
/sw/lib/libopenjp2.7.dylib (compatibility version 7.0.0, current version
2.1.1)
/sw/lib/libjasper.1.dylib (compatibility version 2.0.0, current version
2.0.0)
/sw/lib/libnetcdf.11.dylib (compatibility version 12.0.0, current version
12.4.0)
/sw/lib/libhdf5.10.dylib (compatibility version 12.0.0, current version
12.0.0)
/sw/lib/libogdi31.dylib (compatibility version 3.1.0, current version 3.1.5)
/sw/lib/libgif.7.dylib (compatibility version 8.0.0, current version 8.0.0)
/sw/lib/libjpeg.9.dylib (compatibility version 12.0.0, current version
12.0.0)
/sw/lib/libgeotiff.2.dylib (compatibility version 4.0.0, current version
4.1.0)
/sw/lib/libtiff.5.dylib (compatibility version 8.0.0, current version 8.6.0)
/sw/lib/libpng16.16.dylib (compatibility version 47.0.0, current version
47.0.0)
/sw/lib/liblzma.5.dylib (compatibility version 8.0.0, current version 8.3.0)
/usr/lib/libz.1.dylib (compatibility version 1.0.0, current version 1.2.8)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version
1238.60.2)
/sw/lib/libspatialite.7.dylib (compatibility version 9.0.0, current version
9.0.0)
/sw/lib/libpcre1/libpcre.1.dylib (compatibility version 4.0.0, current
version 4.9.0)
/sw/lib/libcurl.4.dylib (compatibility version 9.0.0, current version 9.0.0)
/sw/lib/libiconv.2.dylib (compatibility version 8.0.0, current version
8.1.0)
/sw/lib/libxml2.2.dylib (compatibility version 12.0.0, current version
12.4.0)
/usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version
307.5.0)
On Sun, Sep 17, 2017 at 11:51 AM, Mateusz Loskot <mateusz at loskot.net> wrote:
> On 17 September 2017 at 11:37, Andrew C Aitchison
> <andrew at aitchison.me.uk> wrote:
> > On Fri, 15 Sep 2017, Even Rouault wrote:
> >> I have prepared a GDAL/OGR 2.2.2 release candidate.
> >> Peek up an archive among the following ones (by ascending size):
> >> http://download.osgeo.org/gdal/2.2.2/gdal-2.2.2RC1.tar.xz
> >> http://download.osgeo.org/gdal/2.2.2/gdal-2.2.2RC1.tar.gz
> >> http://download.osgeo.org/gdal/2.2.2/gdal222RC1.zip
> > No build problems on Scientific Linux 6 with system compiler.
> > No problems using it so far.
> I've run quick check building basic configuration inside "Bash on Windows",
> environment based on Ubuntu 14.04.5 LTS, using GCC 7.2.
> All fine.
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170918/e6615e27/attachment-0001.html>
