[gdal-dev] OGR_L_SetSpatialFilter
Andrew Bell
andrew.bell.ia at gmail.com
Fri Sep 22 13:54:00 PDT 2017
Is there any reason to use OGR_L_SetSpatialFilter if you're fetching a
layer using OGR_DS_Execute_SQL? Am I missing something or can I place
whatever filter (via a where clause) on the SQL statement that I might
otherwise use in a call to OGR_L_SetSpatialFilter?
Thanks,
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170922/46f87baa/attachment.html>
