[gdal-dev] Shapefile: automatic retrieval of EPSG code
Even Rouault even.rouault at spatialys.com
Mon Sep 25 12:43:21 PDT 2017
> Thank you very much, Even! I have only one observation about the first
> example: the standard parallels values are switched in the gdalsrsinfo
> results. So, it seems like that they don't match at all, excluding the
> mapped CRS name. Definitively the confidence in this match, according to
> your definition, should be only 50%.
This is indeed an exception. For Lambert_Conformal_Conic_2SP, the order of
standard parallel is indifferent (and EPSG and ESRI don't use the same order.
Same with MapInfo as far as I remember). This results in the same
mathematical projection. So I've added an exception in IsSame() to accept that
difference.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170925/c86ae122/attachment.html>
