[gdal-dev] ogr2ogr and nlt question
Andreas Neumann
a.neumann at carto.net
Thu Sep 28 23:33:40 PDT 2017
sorry - I meant to say that I convert CURVEPOLYGON to POLYGON, not
COMPOUNDCURVE TO POLYGON.
Andreas
On 2017-09-29 08:32, Andreas Neumann wrote:
> Hi,
> when using ogr2ogr I can fix the geometry type for cases where I use SQL statements.
> Can I use nlt multiple times? In my case I would like to specify -nlt CONVERT_TO_LINEAR to convert from CompounCurve to Polygon and then use -nlt POLYGON to tell it you are really a POLYGON. Is this possible to use the -nlt parameter twice?
> Thank you for your reply,
> Andreas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170929/7514d6ff/attachment.html>
