[gdal-dev] Warped VRT and overviews
Even Rouault
even.rouault at spatialys.com
Fri Sep 29 13:38:59 PDT 2017
Hi Sean,
> It's been my understanding that GDAL's RasterIO (most current version) uses
> overviews when available, implicitly. Is this also true for VRTs and warped
> VRTs or is not true?
Yes, it is supposed to, and below demonstrates a working case of that capability:
(byte.tif is
https://github.com/OSGeo/gdal/blob/trunk/autotest/gcore/data/byte.tif)
gdal_translate byte.tif test.tif -outsize 2048 2048
Create uniformly grey overview:
gdal_translate test.tif test.tif.ovr -outsize 256 256 -scale 0 255 127 127
gdalwarp test.tif test_warped.vrt -of VRT -t_srs EPSG:3857 -overwrite
gdal_translate test_warped.vrt small.tif -outsize 256 256 --debug on
small.tif is grey as expected
> I ask because 1) in reading from a warped VRT (using vsicurl) I'm not
> seeing use of the overviews in the GeoTIFF source that surface in the VRT,
> and
Perhaps you're doing something different from the above ?
> 2) in reading the source of gdalwarp_lib.cpp I see that it has its own
> code for navigating overview levels and does not rely on any implicit
> overviews.
Yes gdalwarp itself can be told which overview level to use from the source raster, but the
VRT warped code also has logic to use overviews of the source raster :
https://github.com/OSGeo/gdal/blob/trunk/gdal/frmts/vrt/vrtwarped.cpp#L550
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170929/3fe5f3a3/attachment.html>
