[gdal-dev] Clip Raster with Polygon C#
Paul Meems
bontepaarden at gmail.com
Tue Apr 3 00:19:56 PDT 2018
Here's a snippet of the code I use:
using (var ds = GDAL.Open(input, Access.GA_ReadOnly))
if (ds == null)
throw new Exception("Can't open GDAL dataset: " + input);
var options = new[]
"-of", "vrt",
"-overwrite",
"-multi",
"-crop_to_cutline",
"-cutline", borderFilename
var gdalOptions = new GDALWarpAppOptions(options);
var ptr = new[] { Dataset.getCPtr(ds).Handle };
var gcHandle = GCHandle.Alloc(ptr, GCHandleType.Pinned);
try
var dss = new
SWIGTYPE_p_p_GDALDatasetShadow(gcHandle.AddrOfPinnedObject(), false, null);
using (var newDs = GDAL.wrapper_GDALWarpDestName(output, 1, dss,
gdalOptions, null, null))
if (newDs == null)
throw new Exception("GdalWarp failed: " + GDAL
.GetLastErrorMsg());
finally
if (gcHandle.IsAllocated)
gcHandle.Free();
return true;
Does this help you?
Regards,
Paul
2018-04-02 22:18 GMT+02:00 tval <tyeik at gktechinc.com>:
> Is it possible to use the Gdal Warp wrapper or another method for clipping
> a
> raster to a polygon? I've tried using Gdal.wrapper_GDALWarpDestName and
> using input datasets such as a .tif and a .shp, but was unsuccessful.
> Perhaps I had the wrong options or inputs. Any help would be appreciated.
> Thanks.
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180403/b68e69ce/attachment.html>
