[gdal-dev] Understanding VSI caching
Even Rouault even.rouault at spatialys.com
Mon Apr 9 09:43:54 PDT 2018
On lundi 9 avril 2018 18:33:32 CEST Andrea Aime wrote:
> Hi,
> is there any document explaning how VSI caching works. E.g., memory vs disk
> caching, whether the disk cache
> is long lived or exists only for the duration of the process (and if so,
> what about long lived processes
> like mapserver fastcgi?) and so on?
Hi Andrea,
Are you speaking about the cache machanism enabled with the VSI_CACHE=YES env variable ?
If so that's described at
http://gdal.org/gdal_virtual_file_systems.html#gdal_virtual_file_systems_vsicache
I see it lacks a bit high level details, like specifying this is RAM only, and not disk cached.
I'm going to add some words about that
Otherwise, the full "documentation" :-) is at:
https://github.com/OSGeo/gdal/blob/master/gdal/port/cpl_vsil_cache.cpp
The /vsicurl/ and related network file systems have also their own RAM cache mechanism
described at
http://gdal.org/gdal_virtual_file_systems.html#gdal_virtual_file_systems_vsicurl
Even
> Cheers
> Andrea
> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
> for more information.
> Ing. Andrea Aime
> @geowolf
> Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39  339 8844549
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
http://www.spatialys.com
