[gdal-dev] help printing the standard out from gdal_grid in python
Sean Gillies
sean at mapbox.com
Thu Apr 12 08:56:15 PDT 2018
Hi Nicolas,
check_output() is higher level and easier to use. I recommend it:
https://docs.python.org/2.7/library/subprocess.html#subprocess.check_output.
There's a note in there about capturing stderr as well. If gdal_grid is
running successfully, there may not be anything in stdout.
I think I see a bug in your code. The function you give to the pool should
take a single arg, not a list. imap_unordered() will pass elements of your
list to workers, not the entire list.
Good luck!
On Thu, Apr 12, 2018 at 9:13 AM, Nicolas Cadieux <
nicolas.cadieux at archeotec.ca> wrote:
> Hi,
> I am not an experienced programmer. I am calling gdal_grid from a python
> script. I am using p.imap_ unordered to multiprocess the script. The idea
> is the following:
> def gdal_Grid(fileList):
> gdal_Grid_Cmd = 'gdal_grid -l ....'
> shell = subprocess.Popen(r'c:\OSGeo4W64\OSGeo4W.bat',
> stdin=subprocess.PIPE)
> shell.communicate(gdal_Grid_Cmd)
> return 'done'
> lst = [c:\temp.csv....]
> if __name__ == '__main__':
> p = Pool(2)
> for x in p.imap_unordered(gdal_Grid,lst):
> print x
> The Question:
> I would like to print the output (standard out???) from gdal_grid. I can't
> figure how to use stdout=subprocess.PIPE. Can you help me?
> Thanks
> Nicolas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180412/0de91ff4/attachment.html>
