[gdal-dev] CPLReadLine2L and control characters
Even Rouault
even.rouault at spatialys.com
Fri Apr 20 14:06:43 PDT 2018
Martin,
> when working on VFK driver improvements [0] I am dealing with various
> problems. I found lines in sample data which contain 0x0x control
> character [1] inside.
You mean 0x00 right ?
I would not expect those to be valid in ISO-8859-2. How are they supposed to be interpreted
? Are you sure the dataset is valid ?
> CPLReadLine2L reads all characters:
> (gdb) p pszRawLine[68]
> $4 = 0 '\000'
> (gdb) p pszRawLine[69]
> $5 = 63 '?'
> (gdb) p pszRawLine[70]
> $6 = 4 '\004'
> (gdb) p pszRawLine[71]
> $8 = 0 '\000'
> (gdb) p pszRawLine[72]
> $7 = 34 '"'
> But then strlen() stops on position 68 and rest of line is simply
> lost. Do you have any idea how to deal with such data in reasonable
> way?
I guess you could transform CPLReadLine2L() into CPLReadLine3L() with an extra int*
pnBufLength output argument that would return the final value of nBufLength, and then you
would lop on the string to remove those annoying nul characters.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180420/1a062ad8/attachment.html>
