[gdal-dev] Warping EUMetsat MSG-4 MPE dataset to webmercator projection
Andre Joost
andre+joost at nurfuerspam.de
Wed Apr 25 10:20:17 PDT 2018
Am 25.04.18 um 15:50 schrieb Kristian Evers:
> Andre,
> The PROJ 5.0.1 OSGeo4W installation is faulty so that may be the
> problem. Specifically the null grid is not being installed in the
> 5.0.1 package as reported on the mailing list [0]. This has not been
> resolved yet. Try copying in the null grid to C:\OSGeo4W64\share\proj
> and see if that changes anything. You can use the file from your
> current 4.9.3 installation.
That does not improve the situation with gdalwarp. I will do some tatest
with cs2cs later.
Greetings,
Andre Joost
