[gdal-dev] Building OpenEV with GDAL 2.2.4
Shannon Fitzpatrick
sbfitzpatrick at rogers.com
Wed Apr 25 13:52:21 PDT 2018
I'm trying to build OpenEV with GDAL 2.2.4 using Visual Studio 2008. I have
been able to build and run OpenEV with GDAL 2.0.2 with Visual Studio 2008.
However, as soon as I move to 2.0.3 OpenEV dies when try and start it. Seems
to be an issue with swig since when you comment out the lines starting at
"SWIGTYPE_p_GDALDatasetShadow = SWIG_TypeQuery("_p_GDALDatasetShadow")" to
the end of the function init_gdal in gvmodule.c OpenEV starts ( You can not
open an image though). Does anyone have any advice to point me in the
correct direction as far as swig and as to which compiler I can have to
expect a little issues as possible with.
Thanks
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180425/8d691035/attachment.html>
