[gdal-dev] VRT pixel functions on tiled vrt
William Kyngesburye
woklist at kyngchaos.com
Thu Apr 26 11:07:15 PDT 2018
So, if the gdal library queries for a region of the vrt (ie processing it in chunks), the numpy array will be just that region? I'll give it a try.
What about something like viewing the whole vrt in QGIS - will it be read in chunks as well? IOW, is it the GDAL library that breaks it into chunks at reading, or is it the responsibility of programs (gdal_translate, QGIS,...) to ask for chunks?
> On Apr 26, 2018, at 12:59 PM, Even Rouault <even.rouault at spatialys.com> wrote:
> On jeudi 26 avril 2018 12:56:10 CEST William Kyngesburye wrote:
> > So, a vrt of a vrt?
> Yes
> > I wanted to avoid that, because as I understand the source, it reads each
> > raster in the derived band as a single numpy array, which would be all the
> > tiled rasters together.
> No, if you use gdal_translate, it will process the source by reasonable chunks, so you should be able to process arbitrarily large sources.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com <http://www.spatialys.com/>_______________________________________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/gdal-dev <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We can die but once, and that once we must die. To be always fearing, then, would not avert it, and would make life miserable."
- Tarzan, on death
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180426/bddcec64/attachment.html>
