[gdal-dev] VRT pixel functions on tiled vrt
Even Rouault
even.rouault at spatialys.com
Fri Apr 27 12:32:46 PDT 2018
On vendredi 27 avril 2018 12:42:16 CEST William Kyngesburye wrote:
> OK, it worked as vrt of a vrt. Memory not an issue.
> But I have a new problem. One vrt I want to instead do > -29 (caspian sea,
> -29 in SRTM data). The whole region evaluates to 1 (true). It looks like
> the in_ar[] is getting truncated to an unsigned byte, 0-255, from its
> orignal Int16.
Check the various data types mentionned in the VRT. Perhaps there's one set to
Byte.
It would also probably be safer to define
<SourceTransferType>GDT_Int16</SourceTransferType>
at the same level than the <PixelFunction...> elements
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180427/888a08ec/attachment.html>
