[gdal-dev] Fwd: Converting Tiff to GeoPackage with Zoom Levels
Gil
gilpeleg at live.com
Sat Apr 28 22:09:53 PDT 2018
Hey Even,
I tried using gdal2.0.2 (deployed with QGIS 3.0) and got this result.
The original Tiff is converted to level 17 of GPKG, and then after the gdaladdo I have level 18 through 10, where 10 has 2 tiles.
This is the output of gdalinfo:
Driver: GTiff/GeoTIFF
Files: C:\myfile.tif
Size is 19968, 29952
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (***, ***)
Pixel Size = (0.000004444518203,-0.000004444518203)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
*** Coordinates data removed ***
Band 1 Block=19968x1 Type=Byte, ColorInterp=Red
Band 2 Block=19968x1 Type=Byte, ColorInterp=Green
Band 3 Block=19968x1 Type=Byte, ColorInterp=Blue
Thanks!
Gil
On 28 April 2018 at 20:59, Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>> wrote:
Please paste the output of gdalinfo C:\myfile.tif
Which gdal version do you use ? What you report sounds a bit like
https://trac.osgeo.org/gdal/ticket/6932
Even
http://www.spatialys.com
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180429/5bed1c61/attachment.html>
