[gdal-dev] Cannot call InvGeoTransform due to too many values to unpack
Jacky Nguyen jackynguyen.km at gmail.com
Wed Aug 1 02:49:16 PDT 2018
Hi Even,
Ahhh, so the code from the book is a bit outdated. Remove the success flag
works now
Thank you!
Jacky
On Wed, Aug 1, 2018 at 3:57 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Jacky,
> > t = dataset.GetGeoTransform()
> > success,tInverse = gdal.InvGeoTransform(t)
> There's no success flag, so
> This will return None in case of failure
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180801/9e1b37ad/attachment.html>
