[gdal-dev] edit geometry with query where
Even Rouault
even.rouault at spatialys.com
Thu Aug 2 07:58:53 PDT 2018
On jeudi 2 août 2018 16:52:19 CEST Jérôme Seigneuret wrote:
> Hi,
> I use QGIS to edit layers and in this soft there is no possibility to edit
> geometry if query where exist. QGIS use OGR driver to read and write
> geometry. I am also an ArcGIS user and I don't have any problem for editing
> my data with query where definition.
> OGR can't really work for editing geometry on shapefile when a query
> definition is set?
That should generally work. The limitation is rather on the QGIS side and
should be reported in its bug tracker, if not already reported.
Even
http://www.spatialys.com
