[gdal-dev] How to copy the EXIF metadata?
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Thu Aug 2 13:17:53 PDT 2018
Referring to this question on gis.stackexchange https://gis.stackexchange.com/questions/291554/how-to-retrieve-exif-tags-from-a-geotiff-with-gdal.
The GTiff driver manual https://www.gdal.org/frmt_gtiff.html informs me that "Starting with GDAL 1.10, EXIF metadata can be extracted from the file, and will be stored the EXIF metadata domain" but is there any example about how to do it? I had a try by downloading this image from GDAL autotests https://raw.githubusercontent.com/OSGeo/gdal/master/autotest/gcore/data/exif_and_gps.tif.
If I run
gdal_translate -of GTiff exif_and_gps.tif exif_and_gps_copy.tif
and test the result with
gdalinfo -listmdd exif_and_gps_copy.tif
it seems that the EXIF metadata domain and tags are dropped.
Test made with GDAL 2.4.0dev.
-Jukka Rahkonen-
