[gdal-dev] gdal wms
Ian Turton ijturton at gmail.com
Mon Aug 6 09:50:11 PDT 2018
You just specify the size of the image of the map that you would like, this
is unrelated to the size of the original file.
Ian
On Mon, 6 Aug 2018 at 16:38, Idan Miara <idan at miara.com> wrote:
> Hi,
> I'm trying to use the gdal_wms driver.
> One of the parameters that I need is the raster size (Width+Height).
> I succeeded using the driver with a GeoTIF that I served via geoserver, so
> I could use gdalinfo to get that info.
> How can I retrieve the raster size for a layer that I don't have a backend
> raster to use with gdalinfo? The size doesn't appear in the GetCapabilities
> of the wms service.
> Kind Regards,
> Idan.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Ian Turton
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180806/03d65246/attachment.html>
