[gdal-dev] Building GDAL with PROJ4 on Android
René Hansen
renehh at gmail.com
Tue Aug 7 03:37:05 PDT 2018
Hey Chris,
>From a previous yak-shaving-adventure, I've dabbled in building Proj and
Geos for Android, because they were dependencies of Spatialite, which I'm
using for an app.
That resulted in a homegrown build system based on docker, aptly named:
Building for Android with Docker. It is meant as a repository for working
build sets for various native libs.
I didn't previously have GDAL in there, but decided to give it a shot and
add it, to see how much effort was required. Not much as it were.
I've added GDAL now, with a compile-time dependency for Proj, so it
shouldn't be more of a hassle than simply checking out the repo and then
"make gdal".
Instructions for how to extract the libraries from the container, is in the
readme. Here's the link to the repo:
https://github.com/rhardih/bad
I've built and tried a very simple Android app, and added some of the
source from https://gdal.org/gdalinfo.c.html, to see if the libs actually
loaded up and Proj was supported. It seems to work just fine. You can find
the example app, source and output here:
https://github.com/rhardih/gdal-proj-android
So far I've only used this project for personal consumption, and I need to
do a lot of grooming and test/writing before it's really ready for public
use, but this might solve your problem in this instance.
Best regards,
René Hansen
On Mon, 6 Aug 2018 at 21:40 Chris Hanson <xenon at alphapixel.com> wrote:
> We have been struggling for months to get osgEarth ( http://osgearth.org/
> ) working on Android using a PROJ4 equipped GDAL 2.x build. We have it
> working with a scratch-built GDAL, but it lacks the PROJ4 capabilities.
> GDAL reports lacking PROJ4 at runtime. The --with-static-proj option is
> said to be deprecated.
> Has anyone successfully built a GDAL 2.x with PROJ4 on Android?
> Chris 'Xenon' Hanson, omo sanza lettere. Xenon at AlphaPixel.com
> http://www.alphapixel.com/
> Training • Consulting • Contracting
> 3D • Scene Graphs (Open Scene Graph/OSG) • OpenGL 2 • OpenGL 3 • OpenGL 4
> • GLSL • OpenGL ES 1 • OpenGL ES 2 • OpenCL
> Legal/IP • Forensics • Imaging • UAVs • GIS • GPS •
> osgEarth • Terrain • Telemetry • Cryptography • LIDAR • Embedded • Mobile •
> iPhone/iPad/iOS • Android
> @alphapixel <https://twitter.com/alphapixel> facebook.com/alphapixel (775)
> 623-PIXL [7495]
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180807/7fc72388/attachment-0001.html>
