[gdal-dev] ImportFromESRIStatePlaneWKT access from python
Glen Rice - NOAA Federal
glen.rice at noaa.gov
Thu Aug 9 06:27:43 PDT 2018
Thanks Even,
>From the SetStatePlane docs
<https://www.gdal.org/classOGRSpatialReference.html#a4e0f1e23207c157f72388717c35be88c>
it says
nZone State plane zone number, in the USGS numbering scheme (as distinct
from the Arc/Info and Erdas numbering scheme."""
which would seem to indicate that using the FIPS code in place of the USGS
numbering scheme will lead to erroneous results. It appears that my best
path forward with FIPS within GDAL with python would be to read
the Lib/site-packages/osgeo/data/gdal/esri_StatePlane_extra.wkt file
directly and build a small converter utility.
Glen
On Thu, Aug 9, 2018 at 9:02 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 9 août 2018 08:42:57 CEST Glen Rice - NOAA Federal wrote:
> > Hello,
> > I am looking for any hints for how to access ImportFromESRIStatePlaneWKT
> in
> > the OGRSpatialReference class through the python bindings. I am working
> > with xyz text files where the header contains a FIPS zone reference and I
> > would like to convert it to another system.
> You can't from Python. This method is only available from C++.
> But perhaps the osr.SetStatePlane(int zone, int is_nad83 = 1, char const
> *unitsname = "", double units = 0.0) that corresponds to
> OGRSpatialReference::SetStatePlane() will do the job ?
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Glen Rice
Hydrographic Systems and Technology Branch
Office of Coast Survey / Coast Survey Development Laboratory
603-862-1397
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180809/9b0e23e0/attachment-0001.html>
