[gdal-dev] ImportFromESRIStatePlaneWKT access from python
Glen Rice - NOAA Federal glen.rice at noaa.gov
Fri Aug 17 13:54:42 PDT 2018
This is a followup comment for completeness in case someone else tries to
go down the same path of ingesting the ImportFromESRIStatePlaneWKT file
directly.
I found that when I used the resulting wkt directly in an instance
of osr.CoordinateTransformation I got the following error:
ERROR 6: No translation for Lambert_Conformal_Conic to PROJ.4 format is
known.
Wrong number or type of arguments for overloaded function
'CoordinateTransformation_TransformPoint'.
  Possible C/C++ prototypes are:
    OSRCoordinateTransformationShadow::TransformPoint(double [3])
[3],double,double,double)
After some mucking around I found that updating the PROJECTION from
"Lambert_Conformal_Conic" to "Lambert_Conformal_Conic_2SP" fixed the
problem.
Kind regards,
Glen
On Thu, Aug 9, 2018 at 9:40 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 9 août 2018 09:27:43 CEST Glen Rice - NOAA Federal wrote:
> > Thanks Even,
> > From the SetStatePlane docs
> > <https://www.gdal.org/classOGRSpatialReference.html#
> a4e0f1e23207c157f7238871
> > 7c35be88c> it says
> > nZone State plane zone number, in the USGS numbering scheme (as distinct
> > from the Arc/Info and Erdas numbering scheme."""
> > which would seem to indicate that using the FIPS code in place of the
> USGS
> > numbering scheme will lead to erroneous results.
> The mapping from USGS (left column) to ESRI (right column) zone number is
> at:
> https://github.com/OSGeo/gdal/blob/master/gdal/ogr/ogr_srs_esri.cpp#L134
> and ultimately this reads the data/stateplane.csv with the USGS zone
> number as
> a key.
> > It appears that my best
> > path forward with FIPS within GDAL with python would be to read
> > the Lib/site-packages/osgeo/data/gdal/esri_StatePlane_extra.wkt file
> > directly and build a small converter utility.
> Sounds reasonable
> > Glen
> > On Thu, Aug 9, 2018 at 9:02 AM, Even Rouault <even.rouault at spatialys.com
> > wrote:
> > > On jeudi 9 août 2018 08:42:57 CEST Glen Rice - NOAA Federal wrote:
> > > > Hello,
> > > > I am looking for any hints for how to access
> > > in
> > > > the OGRSpatialReference class through the python bindings.  I am
> working
> > > > with xyz text files where the header contains a FIPS zone reference
> and
> > > > I
> > > > would like to convert it to another system.
> > > You can't from Python. This method is only available from C++.
> > > But perhaps the osr.SetStatePlane(int zone, int is_nad83 = 1, char
> const
> > > *unitsname = "", double units = 0.0) that corresponds to
> > > OGRSpatialReference::SetStatePlane() will do the job ?
> > > Even
> > > Spatialys - Geospatial professional services
> > > http://www.spatialys.com
Glen Rice
Hydrographic Systems and Technology Branch
Office of Coast Survey / Coast Survey Development Laboratory
603-862-1397
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180817/65d17764/attachment.html>
