[gdal-dev] GDAL with podofo can't process pdf documents generated by ArcGIS
Andreas Oxenstierna
ao at t-kartor.se
Mon Aug 20 23:11:00 PDT 2018
Hi
I have also encountered similar issues with PDFs from other Windows
softwares.
The workaround I use is to recreate the PDF in any available software
which ignores missing EOFs, endstreams etc.
Programmatically, this can be done as described in
https://codedprojects.wordpress.com/2017/06/09/how-to-fix-pypdf-error-eof-marker-not-found/
> Hi all,
> I'm currently working on a map viewer application that uses GDAL for
> processing geo-referenced map images. Up till now I've been
> successfully using the poppler library for PDF support, but am
> currently trying to shift to the podofo/poppler hybrid approach
> (podofo library with poppler pdftoppm utility) to work around
> poppler's GPL licence restrictions.
> I have a collection of sample map PDF documents generated by ESRI
> ArcMap 10 (different documents from different releases in the 10.x
> release family), which I could successfully process with GDAL/poppler,
> but most of which fail to load with GDAL/podofo. The document loading
> also fails with the stand-alone podofo pdftoppm utility, both with a
> version that I've built from podofo 0.9.6 source and with the 0.9.3
> version installed onto my ubuntu xenial machine from the APT package
> repository.
> The typical error message is as follows:
> Error: An error 5 ocurred during uncompressing the pdf file.
> PoDoFo encounter an error. Error: 5 ePdfError_UnexpectedEOF
> Error Description: End of file was reached unxexpectedly.
> Callstack:
> #0 Error Source:
> /build/libpodofo-NltoF1/libpodofo-0.9.3/src/base/PdfParser.cpp:226
> Information: Unable to load objects from file.
> #1 Error Source:
> /build/libpodofo-NltoF1/libpodofo-0.9.3/src/base/PdfParser.cpp:334
> Information: Unable to load xref entries.
> #2 Error Source:
> /build/libpodofo-NltoF1/libpodofo-0.9.3/src/base/PdfParser.cpp:738
> #3 Error Source:
> /build/libpodofo-NltoF1/libpodofo-0.9.3/src/base/PdfTokenizer.cpp:339
> which seems to indicate an invalid xref table.
> I don't think this is a podofo bug as such, as various online pdf
> validators I've tried also flag the documents as problematic, but
> several other bits of pdf software I've tried (notably the poppler
> library utilities) seem to treat it as a non-fatal recoverable error.
> Has anyone else come across this and come up with a work-around or fix?
> Example problem file to be found at
> https://www.dropbox.com/s/khlzgz8o2gxq89y/6090_harvest.pdf?dl=0
> thanks
> Richard.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Best regards
Andreas Oxenstierna
T-Kartor Geospatial AB
mobile: +46 733 206831
mailto: ao at t-kartor.se
http://www.t-kartor.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180821/698b0db5/attachment.html>
