[gdal-dev] Offsets in url of geotiff
Guy Doulberg
guyd at satellogic.com
Thu Aug 23 00:51:55 PDT 2018
Thanks,
that will do exactly what I wanted, I wasn't ware of the behavior in VRT
On Thu, Aug 23, 2018 at 10:25 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 23 août 2018 09:29:27 CEST Guy Doulberg wrote:
> > Hi
> > I want to share with you an idea I had,
> > I am storing rasters as cloud optimized GeoTiff, these rasters can cover
> > very big areas.
> > I was thinking it could be super, if I could share a link to my
> colleagues
> > of a raster with the offset they need encoded in the raster.
> > for example:
> > url = "/vsicur/http://location/#srcwin=(xoff,yoff,szie,ysize)"
> That mixes completely different levels of abstractions. The source window
> is a
> high level concept, whereas the resource is at the byte level.
> One possibility would be that you share the VRT file resulting from
> gdal_translate -srcwin [...] /vsicurl/.... windowed.vrt -of VRT
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180823/beea781f/attachment.html>
