[gdal-dev] PG driver: apply custom sql files together with loading data in one transaction
Even Rouault
even.rouault at spatialys.com
Fri Aug 31 01:31:46 PDT 2018
On vendredi 31 août 2018 10:20:49 CEST Martin Landa wrote:
> Hi,
> čt 30. 8. 2018 v 16:28 odesílatel Even Rouault
> <even.rouault at spatialys.com> napsal:
> > API by yourself to do ogr2ogr-like ingestion, and then ExecuteSQL() for
> > your customizations.
> great, first tests with ExecuteSQL(fd.read()) went well. Unfortunately
> the method returns always None regardless of success or failure.
Yes it will return either None either a result set layer if the command is
typically a SELECT or something that returns rows.
> Is
> there any way how to catch up errors when executing SQL commands by
> ExecuteSQL()?
testing CPLGetLastErrorType() != CE_None
Even
http://www.spatialys.com
