[gdal-dev] Is writing/reading a VRTs an atomic operation?
Pablo Sanfilippo sanfilippopablo at gmail.com
Thu Dec 6 09:46:18 PST 2018
Thanks!
On Thu, Dec 6, 2018 at 2:25 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 6 décembre 2018 13:59:07 CET Pablo Sanfilippo wrote:
> > Hello!
> > I'm building an application in which I will have multiple concurrent
> > process reading and writing to a VRT file. The writers are just multiple
> > instances of the same process that create a .vrt off a list of tiffs in a
> > folder. The writer process implement file locking, so I'm sure no two
> > processes will try to write the .vrt at the same time. But the readers
> > (which are gdal_translate calls that use the .vrt as input) don't lock
> the
> > .vrt so they can be ran at the same time. I can see a race condition
> > happening if gdalbuildvrt overwrites the file when some gdal_translate is
> > opening it. So, if I'm understanding this correctly, the question boils
> > down to: Is the read call that gdal_translate makes when reading a vrt
> file
> > atomic? And is the write call that gdalbuildvrt makes when writing the
> file
> > atomic?
> Much likely not. At least there's no effort in the code to make read/write
> atomic.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181206/6528ba76/attachment.html>
