[gdal-dev] Lost in decimals... geotransform in python 2.7
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Sun Dec 9 08:42:27 PST 2018
I am trying to get the four corners of a raster the size of Canada (very
big therefore decimals count).  If I get the geotransform, I get:
geotransform: (-132.00041666666667, 0.0008333333333333334, 0.0,
53.000416666666666, 0.0, -0.0008333333333333334)
In Python 2.7:
print (geotransform[0]) ->               -132.000416667
print float(geotransform[0]) ->       -132.000416667
print str(geotransform[0]) ->           -132.000416667
print Decimal(geotransform[0]) ->
-132.000416666666666287710540927946567535400390625
In Qgis3x (on Windows64), I get:    -132.0004166666666663 in the layer
properties.
Qgis looks like the end result of:
getcontext().prec = 19
print Decimal(geotransform[0])/Decimal(1)
Must I use "Decimals" to deal with the geotransform output? Using float
will truncate the decimal place and I may end up with an extra pixel row
or column because of the size of the raster. So what is the proper way
to work with this?
Thanks
Nicolas
