[gdal-dev] Member function GDALRasterBand::RasterIO has	inconsistent declaration and implementation
    Even Rouault
    even.rouault at spatialys.com
    Fri Dec 14 02:21:03 PST 2018
On vendredi 14 décembre 2018 06:48:51 CET HU Yaoyu wrote:
> Hi all,
> I am a new guy to GDAL. I encountered a simple problem when trying to
> link against the GDAL library.
> I am working with Version 2.3.2 and Ubuntu 16.04 LTS 64bit. I downloaded
> the source code, did a configure with no arguments and compiled the
> library. After compiling, I performed an install operation to install
> GDAL to /usr/local.
I presume the gdal.h your code is including comes from an older version of
GDAL.
Even
http://www.spatialys.com
