[gdal-dev] How to use Gdal c# bindings with .NET Core
Tamas Szekeres szekerest at gmail.com
Sat Dec 15 10:42:59 PST 2018
At the moment it looks like only the 3rd option below supports .net core.
However since that is a custom build, use the dependencies
(gdal_wrap.dll etc.) provided by the same bundle, ie:
https://www.nuget.org/packages/Gdal.Core.WindowsRuntime/2.3.0-beta-023
These dll-s support x64 only as far as I see.
Best regards,
Tamas
Gigas002 <gigas002 at yandex.ru> ezt írta (időpont: 2018. dec. 15., Szo,
15:50):
> Hello everyone. I'm trying to use c# bindings with .NET Core 2.0 on Visual
> Studio 2017.
> Tried to use multiple nuget packages:
> 1. https://www.nuget.org/packages/GDAL/ +
> https://www.nuget.org/packages/GDAL.Native/
> I used these packages for my .NET Framework project and it worked fine, but
> it doesn't compile on .NET Core. The namespace OSGeo just couldn't been
> seen
> and " 'GDAL.Native 2.3.2' package was restored using
> '.NETFramework,Version=v4.6.1' " warning is thrown by VS.
> 2. https://www.nuget.org/packages/GDAL.NET/
> Throws the same warning about .NET Framework 4.6.1 and requires to write
> GdalConfiguration class, because Gdal.AllRegister() method wouldn't work.
> 3. https://www.nuget.org/packages/Gdal.Core/2.3.0-beta-023 +
> https://www.nuget.org/packages/Gdal.Core.WindowsRuntime/2.3.0-beta-023 +
> https://www.nuget.org/packages/Gdal.Core.LinuxRuntime/2.3.0-beta-023
> Doesn't throw any warnings/errors, compiles fine and Gdal.AllRegister()
> method works OK.
> So, the built application works with the 3rd set of packages. But after
> building the app, I use VS's "publish" to create standalone win-x64 and
> linux-x64 app. And this version doesn't work at all.
> At first it throws exception, because it couldn't find gdal_wrap.dll, if
> I'll copy all needed dll's and the content from gdal-data directory from
> pre-built gdal binaries (taken from here for example:
> http://www.gisinternals.com/query.html?content=filelist&file=release-1911-x64-gdal-mapserver.zip
> to the directory with published .exe file, it'll throw another error:
> System.EntryPointNotFoundException: Unable to find an entry point named
> 'CSharp_OSGeofGDAL_AllRegister___' in DLL 'gdal_wrap'.
> So, probably I'm doing something wrong? Is there a complete guide how to
> use
> gdal bindings with .NET Core to built standalone application? Thanls in
> advance for your reply!
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181215/031359ae/attachment.html>
