[gdal-dev] gdalwarp cutline shift between raster and vector in GDAL 2.3.2
Pedro Venâncio
pedrongvenancio at gmail.com
Mon Dec 17 06:25:02 PST 2018
Hi Andre,
Given the magnitude of the shift, I suspected that could be due to the lack
of +towgs84 parameters of ESRI 102164.
But I does not understand why it worked correctly in GDAL 2.2.2.
Now I see that
C:\>gdalinfo --version
GDAL 2.3.2, released 2018/09/21
C:\>gdalsrsinfo EPSG:102164
PROJ.4 : +proj=tmerc +lat_0=39.66666666666666 +lon_0=-8.131906111111112
+k=1 +x_0=200000 +y_0=300000 +ellps=intl +units=m +no_defs
OGC WKT :
PROJCS["Lisboa_Hayford_Gauss_IGeoE",
GEOGCS["GCS_Datum_Lisboa_Hayford",
DATUM["Datum_Lisboa_Hayford",
SPHEROID["International_1924",6378388.0,297.0]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["False_Easting",200000.0],
PARAMETER["False_Northing",300000.0],
PARAMETER["Central_Meridian",-8.131906111111112],
PARAMETER["Scale_Factor",1.0],
PARAMETER["Latitude_Of_Origin",39.66666666666666],
UNIT["Meter",1.0],
AUTHORITY["Esri","102164"]]
while
pedro at pedro-VirtualBox:~$ gdalinfo --version
GDAL 2.2.2, released 2017/09/15
pedro at pedro-VirtualBox:~$ gdalsrsinfo EPSG:102164
ERROR 1: ERROR - failed to load SRS definition from EPSG:102164
I checked and in both versions, this SRS is listed in proj esri file as
# Lisboa Hayford Gauss IGeoE
<102164> +proj=tmerc +lat_0=39.66666666666666 +lon_0=-8.131906111111112
+k=1.000000 +x_0=200000 +y_0=300000 +ellps=intl +units=m no_defs <>
and not in the epsg file.
So, is there any explanation for the different behaviour between those
versions?
Thank you very much!
Best regards,
Pedro
Andre Joost <andre+joost at nurfuerspam.de> escreveu no dia segunda,
17/12/2018 à(s) 13:17:
> Hi Pedro,
> if you compare gdalsrsinfo epsg:20790 and gdalsrsinfo EPSG:102164 from
> ESRI, you see that ESRI omits the datum shift between Lisbon Hayford and
> WGS84.
> So you should use -s_srs EPSG:20790 to get the warping correctly.
> HTH,
> Andre Joost
> Am 17.12.18 um 11:09 schrieb Pedro Venâncio:
> > Hi,
> > I'm getting an error when clipping a raster by a mask layer, in GDAL
> 2.3.2.
> > This beaviour does not happen in GDAL 2.2.2.
> > To be more specific, in a Windows machine with GDAL 2.3.2, the clip is
> > done, but the image is clipped about 200 meters away from the correct
> > bounding box of the vector layer.
> > In Linux, with GDAL 2.2.2, the clip is done exactly by the vector
> bounding
> > box, as expected.
> > The command I'm using is just:
> > gdalwarp -of GTiff -tr 4.235097023884323 -4.2350970238843235 -tap
> -cutline
> > PATH_TO_FOLDER\Cartograma_20790_19D.gpkg -dstalpha
> > PATH_TO_FOLDER\19-D_clip.tif
> > The distance of the error made me think that could be something related
> to
> > the coordinate system. In fact, the aux.xml file from the raster layer
> (in
> > jpg format), and which must have been generated in some ESRI software,
> has
> > the EPSG:20790 coordinate system declared as:
> > <SpatialReference xsi:type="typens:ProjectedCoordinateSystem">
> <WKT>PROJCS["Lisboa_Hayford_Gauss_IGeoE",GEOGCS["GCS_Datum_Lisboa_Hayford",DATUM["D_Datum_Lisboa_Hayford",SPHEROID["International_1924",6378388.0,297.0]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",200000.0],PARAMETER["False_Northing",300000.0],PARAMETER["Central_Meridian",-8.131906111111112],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",39.66666666666666],UNIT["Meter",1.0],AUTHORITY["Esri",102164]]</WKT>
> > <XOrigin>-5423400</XOrigin>
> > <YOrigin>-14095000</YOrigin>
> > <XYScale>450251902.2805022</XYScale>
> > <ZOrigin>-100000</ZOrigin>
> > <ZScale>10000</ZScale>
> > <MOrigin>-100000</MOrigin>
> > <MScale>10000</MScale>
> > <XYTolerance>0.001</XYTolerance>
> > <ZTolerance>0.001</ZTolerance>
> > <MTolerance>0.001</MTolerance>
> > <HighPrecision>true</HighPrecision>
> > <WKID>102164</WKID>
> > <LatestWKID>102164</LatestWKID>
> > </SpatialReference>
> > Simply making a gdal_translate -a_srs EPSG:20790 to the original raster
> > layer, produces the following info in the aux.xml:
> > <PAMDataset>
> > <SRS>PROJCS["Lisbon (Lisbon) / Portuguese National
> > Grid",GEOGCS["Lisbon
> > (Lisbon)",DATUM["Lisbon_1937_Lisbon",SPHEROID["International
> 1924",6378388,297,AUTHORITY["EPSG","7022"]],TOWGS84[-304.046,-60.576,103.64,0,0,0,0],AUTHORITY["EPSG","6803"]],PRIMEM["Lisbon",-9.131906111111112,AUTHORITY["EPSG","8902"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4803"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",39.66666666666666],PARAMETER["central_meridian",1],PARAMETER["scale_factor",1],PARAMETER["false_easting",200000],PARAMETER["false_northing",300000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["X",EAST],AXIS["Y",NORTH],AUTHORITY["EPSG","20790"]]</SRS>
> > <GeoTransform> 1.6169619321196713e+05, 4.2462876699946506e+00,
> > -9.3136981756810518e-03, 3.6360765297460271e+05,
> 4.1234595692999079e-03,
> > -4.2324755960434057e+00</GeoTransform>
> > </PAMDataset>
> > Making the gdalwarp cutline to this new raster layer, with EPSG:20790
> > assigned, already gives the correct output.
> > So, the strange thing is the diferent beaviour between GDAL 2.2.2 and
> > 2.3.2. Can this be a bug in GDAL 2.3.2?
> > Here is a sample dataset to test:
> > https://cld.pt/dl/download/0fcb8923-ed23-45a0-b518-0e5168d0cc0b/19-D.zip
> > Thank you very much.
> > Best regards,
> > Pedro Venâncio
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181217/04b45011/attachment-0001.html>
