[gdal-dev] Piping ogr2ogr (SHP format) /vsistdout/ to unix command
umbertofilippo
umbertofilippo at tiscali.it
Tue Dec 18 00:08:32 PST 2018
Even Rouault-2 wrote
> On lundi 17 décembre 2018 16:00:30 CET umbertofilippo wrote:
> No, you can't pipe a shapefile. This is a multi file format, and OGR
> updates
> the files in a non sequential way. You have to create a temporary
> shapefile
> and zip it afterwards.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Thank you Even, will create the temp file then.
Regards,
Umberto
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
