[gdal-dev] Linux continuus integration failure
Alan Stewart
astewart at terragotech.com
Tue Dec 18 13:41:26 PST 2018
Ubuntu 18.04.1 LTS
I am doing 'git clone' of master from OSGO/gdal and running the gdal/ci/travis/ubuntu_1804 scripts. Script.sh is terminating with failures of four tests from ogr_fgdb.py. There is a summary of those below. In theory these should all pass, as the GitHub Travis CI was passing at the time I cloned yesterday. Any suggestions re what could be wrong appreciated.
def test_ogr_fgdb_13():
ds = ogrtest.fgdb_drv.CreateDataSource(name)
gdal.PopErrorHandler()
> assert ds is None
E AssertionError: assert <osgeo.ogr.DataSource; proxy of <Swig Object of type 'OGRDataSourceShadow *' at 0x7fa77faf11b0> > is None
ogr_fgdb.py:774: AssertionError
def test_ogr_fgdb_19():
for case in ('CASE4', 'CASE5'):
(bPerLayerCopyingForTransaction, ds) = ogr_fgdb_19_open_update('tmp/test.gdb')
> assert ds.StartTransaction(force=True) == 0
E AttributeError: 'NoneType' object has no attribute 'StartTransaction'
ogr_fgdb.py:1407: AttributeError
def test_ogr_fgdb_19bis():
ds = ogr.Open('tmp/test.gdb')
gdal.PushErrorHandler()
> ret = test_ogr_fgdb_19()
ogr_fgdb.py:1562:
def test_ogr_fgdb_20():
ogrtest.openfilegdb_drv.Register()
ds = ogr.Open('tmp/test.gdb', update=1)
ogrtest.openfilegdb_drv.Deregister()
ogrtest.fgdb_drv.Deregister()
# Force OpenFileGDB first
ogrtest.fgdb_drv.Register()
> lyr = ds.CreateLayer('ogr_fgdb_20', geom_type=ogr.wkbNone)
E AttributeError: 'NoneType' object has no attribute 'CreateLayer'
ogr_fgdb.py:1594: AttributeError
Alan Stewart
Senior Software Engineer
TerraGo Technologies
3200 Windy Hill Road, Suite 1550W
Atlanta, GA 30339 USA
O. +1 678.391.9615
www.terragotech.com<applewebdata://B24C0762-C7C9-4431-8518-ACC915448B89/www.terragotech.com>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181218/9b10bb8a/attachment-0001.html>
