[gdal-dev] Error of reading data stored on NFS
Denis Rykov
rykovd at gmail.com
Fri Dec 28 04:39:54 PST 2018
$ gdal_translate
/scratch/abel/UPM000_PILO00/DATA_SOURCES/raw_data/IMG_rebrotes_Guaviyu_191218.tif
output.tif
Input file size is 60613, 75538
0...10...20...30...40...50...60...70...80...90...ERROR 1:
_tiffSeekProc:Invalid argument
ERROR 1: TIFFFillTile:Seek error at row 45440, col 75392, tile 279542
ERROR 1: TIFFReadEncodedTile() failed.
ERROR 1:
/scratch/abel/UPM000_PILO00/DATA_SOURCES/raw_data/IMG_rebrotes_Guaviyu_191218.tif,
band 1: IReadBlock failed at X offset 356, Y offset 589
ERROR 1: GetBlockRef failed at X block offset 356, Y block offset 589
If copy this file to local directory and do the same command all works
without problem.
Does it mean that file is broken or it can be problem of misconfigured NFS?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181228/117d6371/attachment.html>
