[gdal-dev] ogr2ogr not recognizing source SRS correctly
Christoph Paulik
cpaulik at vandersat.com
Thu Feb 1 02:20:46 PST 2018
I've got a shapefile in EPSG:28992 -
http://spatialreference.org/ref/epsg/amersfoort-rd-new/ which I want to
project into a different EPSG.
But this leads to a shift in the projected output if I don't explicitly
specify the s_srs option in ogr2ogr.
So
ogr2ogr AA-maas-EPGS-4326.shp AaMaas.shp -t_srs EPSG:4326 -s_srs EPSG:28992
works correctly
But doing
leads to a shift of the shapefile.
The .prj file is of course there.
Should I file a bug or am I doing something wrong?
All the best,
Christoph
Christoph Paulik
VanderSat // Remote Sensing Scientists
Wilhelminastraat 43a, 2011 VK, Haarlem (NL), The Netherlands
W: www.vandersat.com
PGP: 8CFC D7DF 2867 B2DC 749B 1B0A 6E3B A262 5186 A0AC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180201/5421d2cc/attachment.sig>
