[gdal-dev] RGB to PALETTE conversion
Chris Smemoe
csmemoe at aquaveo.com
Mon Feb 5 13:39:16 PST 2018
Paulo,
Are you trying to convert a file with multiple bands (RGB or RGBA) to a file
with a single band and a color palette? One possible solution showing how
to do this using GDAL is shown on Stack Exchange at the following location:
https://gis.stackexchange.com/questions/246045/export-geotiff-with-color-tab
le-from-web-service-using-gdal-translate/259414#259414
Somebody might have something better.
I imagine you could use a similar solution to handle CMYK images.
Chris
-----Original Message-----
From: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Paulo
Pires
Sent: Sunday, February 04, 2018 4:30 AM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] RGB to PALETTE conversion
theres any help, please?
RGB to Palette...
CMYK to Palette...
Thanks
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
