[gdal-dev] Does ogr2ogr -overwrite truncate also the spatial index in GeoPackage?
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Tue Feb 6 05:02:11 PST 2018
That was the case, once I updated into recent trunk the error message disappeared.
-Jukka-
Lähettäjä: Even Rouault [mailto:even.rouault at spatialys.com]
Lähetetty: 6. helmikuuta 2018 14:54
Vastaanottaja: gdal-dev at lists.osgeo.org
Kopio: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
Aihe: Re: [gdal-dev] Does ogr2ogr -overwrite truncate also the spatial index in GeoPackage?
Jukka,
Which version do you use ? If it is a trunk version before Jan 23, you may run into the bug fixed by https://trac.osgeo.org/gdal/changeset/41325
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180206/a553c5ab/attachment.html>
