[gdal-dev] S57 objects’ catalog reload
Even Rouault
even.rouault at spatialys.com
Fri Feb 9 05:52:38 PST 2018
Jerome,
> I would like to change the s57 objects’ catalog while running between two
> open of datasources. How can I make S57ObjectClasses.csv reloaded ?
> Or how can I change the loaded S57ObjectClasses ?
If your workflow is
open dataset 1
work with it
close dataset 1
change .csv file
open dataset 2
work with it
close dataset 2
then after "change .csv file", you could unload and reload the S57 driver so that the
S57ClassRegistrar singleton gets destroyed and reloaded, with something like (untested):
GDALDriverManager* poDM = GetGDALDriverManager();
GDALDriver* poDrv = poDM->GetDriverByName("S57");
poDM->DeregisterDriver(poDrv);
delete poDrv;
RegisterOGRS57();
If you need to operate on 2 simultaneously opened datasets with different .csv files, then
changes would be needed in the S57 driver.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180209/5ed00bed/attachment.html>
