[gdal-dev] Vector Tiles in OGR
Jeremy Palmer palmerjnz at gmail.com
Tue Feb 13 10:42:13 PST 2018
> OK, I've added a TILING_SCHEME dataset creation option to define such as
> custom tiling scheme. See
> https://trac.osgeo.org/gdal/changeset/41470#file1
> for how to use it and how it impacts metadata.json
> Note that this is only implement for file tilesets and not for MBTILES
> output. That could be extended for MBTILES, but I was a bit hesitant to do
> so to avoid incompatibilities with other tools.
> (Actually by using mb-util you could create a .mbtiles from the file
> tileset)
> Even
Great news. Is it possible to provide a user defined list of resolutions
for the custom scheme which are not power of two? e.g like
https://www.linz.govt.nz/data/linz-data-service/guides-and-documentation/nztm2000-map-tile-service-schema
Cheers
Jeremy
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180214/80459b9f/attachment.html>
