[gdal-dev] Check validity of geometries before writing them into vector tiles?
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Wed Feb 14 07:10:57 PST 2018
I admit that my test was somewhat lunatic but I took some random dataset from Finland with 68101 polygons and converted data into MVT with default settings which means that minzoom was 0. As a result 12196 of the source polygons were written into the 0-level protobuf tile (in EPSG:3067 gridset) and none of the polygons is valid. Most polygons have too few points and those which have enough points have self-intersections.
Perhaps there should be some sort of geometry validator in the writer chain?
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180214/c0df149c/attachment.html>
