Am Mo, 19.02.2018, 16:01 schrieb Bas Couwenberg: > Packages involved in the circular dependency cannot be updated because > the old versions are kept around. > > See: [snip] Thanks for your kind and detailed explanation. I will continue to build and use it in a chroot :)
