[gdal-dev] State and future of GDAL's Java interface
Kurt Schwehr
schwehr at gmail.com
Wed Feb 21 12:47:26 PST 2018
Another area for improvements would seem to be returning List<String>
rather than Vector for things that only return a list of strings. Yes?
e.g. The @SuppressWarnings("unchecked") is a bummer:
@Test
public void fileSystemsPrefixes() throws Exception {
// Convert from Vector.
List<String> prefixes = gdal.GetFileSystemsPrefixes();
assertThat(prefixes)
.containsAllOf(
"/vsicrypt/",
"/vsigzip/",
On Wed, Feb 21, 2018 at 10:32 AM, Kurt Schwehr <schwehr at gmail.com> wrote:
> Hi all,
> What are peoples thoughts on the SWIG/JNI interface to GDAL? In using it
> a little bit, I have some questions for the community.
> 1. Many functions drop type safety and go with raw int. e.g. gdalconst...
> Would people be open to using Enums?
> 2. There are many useful functions that are not SWIG wrapped for Java.
> e.g. I don't see a way to get bytes to or from /vsimem (or others)
> directly (without using a raster or vector driver). Are there thoughts on
> adding those?
> 3. There is no java in autotest. Are folks up for the addition of some
> testing? I've been working on JUnit 4 tests that I can contribute (and
> switch to the GDAL license). I will start putting what I have in autotest2
> soon so at least folks can see what I have
> 4. What is the minimum version of Java that we must support? Can we
> safely add to the java side using features from newer versions? e.g. try
> with resources in https://gist.github.com/schwehr/
> 481dfbfad98815c6d45c3d22f12c41d0
> Thanks,
> -kurt
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180221/dc9e599e/attachment.html>
