Hi, Why is it that in gdal.WarpOptions the output projection is called dstSRS while in gdal.RasterizeOptions it is called outputSRS? Is there a difference and if not, why is not the same name used? Thanks, Johan -- Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
