[gdal-dev] r41166 broke the android build by using std::to_string
Kurt Schwehr schwehr at gmail.com
Tue Jan 2 11:34:45 PST 2018
+gdal-dev (oops!)
On Tue, Jan 2, 2018 at 11:34 AM, Kurt Schwehr <schwehr at gmail.com> wrote:
> Alan,
> https://trac.osgeo.org/gdal/changeset/41166 broke the android build.  e.g.
> https://travis-ci.org/OSGeo/gdal/jobs/324249526
> I tried upgrading the android build to r16b and fixed up the includes, but
> no luck.  Either the android build needs to switch from gcc to clang (which
> may fix the build) or you need to replace std::to_string with something
> else.  I'd vote for switching to clang, but I'm not up for doing that right
> now.
> My attempts to fix:
> https://trac.osgeo.org/gdal/changeset/41168
> https://trac.osgeo.org/gdal/changeset/41169
> -kurt
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180102/a0050739/attachment.html>
