[gdal-dev] CPLJSONDocument
Kurt Schwehr schwehr at gmail.com
Fri Jan 5 08:05:25 PST 2018
I think the more important factors than speed for a C++ lib are: security,
stability, maintainability, and memory usage (low stack usage and
constrainable heap).
I really don't want to have us go through yet more piles of fuzzer bugs for
a library we depend on.  It would be nice to have that already done well by
the lib.
On Fri, Jan 5, 2018 at 7:54 AM, Kurt Schwehr <schwehr at gmail.com> wrote:
> +1 for wrapping the old C code in some cleaner abstractions!
> But +10 for switching to a from the ground up C++ JSON library unless
> there are clear reasons for a core C library (I don't think there are)
> If we are talking about this kind of code, there are several things that
> have bugged me in general about GDAL for a long time.
> * Passing char *psz yada all over the place in pure C++ code.  A const
> std::string is usually not a noticeable expense and is a lot safer
> * CPLString when std::string will do just fine.  And we can write free
> functions to operate on strings.  I'm generally bothered by subclassing of
> std::string as CPLString.  After reading large amounts of C++ code, I think
> it adds more confusion than it ever helps over having clean free
> functions.  Interop and analysis with CPLString's is no fun.
>   https://stackoverflow.com/questions/6006860/why-should-
> one-not-derive-from-c-std-string-class
> -kurt
> On Fri, Jan 5, 2018 at 7:44 AM, Sean Gillies <sean at mapbox.com> wrote:
>> Hi Dmitry,
>> I scanned the PR and it seems reasonable to me. I'm barely a C++
>> programmer at all and it's clear to me, more clear than before. That said,
>> I'm not a fan of wrapping things that could be replaced. Have you looked
>> into whether a more performant C++ JSON library could be used? I haven't
>> run the benchmarks, but json-c compares pretty poorly to others in
>> https://github.com/miloyip/nativejson-benchmark.
>> On Wed, Jan 3, 2018 at 12:04 PM, Dmitry Baryshnikov <bishop.dev at gmail.com
>> > wrote:
>>> Hi everybody,
>>> Happy new year and lot of success in 2018!
>>> I would like to discuss my pull request https://github.com/OSGeo/gdal/
>>> pull/282
>>> I created a thin wrapper around the json-c library which wide using in
>>> GDAL.
>>> This is C++ interface which hides C memory management and provides nice
>>> API. The web or disk json documents reading chunk by chunk with progress
>>> indication also added.
>>> In future, the json-c can be easily switch to something other without
>>> breaking the existing code.
>>> The CPLJSONDocument/CPLJSONObject/CPLJSONArray usage examples can be
>>> found in frmts/pds driver and c++ unit test in autotest/cpp/test_cpl.cpp.
>>> Is this ready to merge into the trunk? Any objections?
>>> Best regards,
>>>     Dmitry
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180105/053d45b6/attachment.html>
