[gdal-dev] CPLJSONDocument
Dmitry Baryshnikov
bishop.dev at gmail.com
Tue Jan 9 00:10:12 PST 2018
I changed CPLJSONObject/CPLJSONArray methods string parameters to
std::string and merged last trunk changes.
Still leave 3 methods with const char* to simplify code because
according to standard conversion sequence, methods with input (const
char*, const char*) parameters executes method with signature
(std:;string&, bool):
Add("key", "value") --> Add(std::string osName, bool bValue)
Set("key", "value") --> Set(std::string osName, bool bValue)
See notes in pull request
(https://github.com/OSGeo/gdal/pull/282#issuecomment-355766795).
I'm ready to merge current pull request into the trunk.
Best regards,
Dmitry
05.01.2018 23:43, Kurt Schwehr пишет:
> My preference (and not speaking for the gdal community) for C++ classes
> would be:
> 1. replace const char * -> const std::string &
> 2. replace CPLString -> std::string
> std::string GetString(const std::string &soName, const std::string
> &soDefault = "") const;
> This is where it would be good to get input from others.
> I base the above on maximizing safety while trying to let the compiler do
> its best job at optimizing. Then in about 2022, we can see about
> std::string_view :(
> On Fri, Jan 5, 2018 at 12:26 PM, Dmitry Baryshnikov <bishop.dev at gmail.com>
> wrote:
>> Hi Kurt,
>> Can you explain what should be done in PR?
>> Do you mean to replace all const char* to?
>> 1. const char* -> const CPLString &
>> const char *GetString(const char *pszName, const char *pszDefault = "")
>> const; ->
>> CPLString GetString(const CPLString &soName, const CPLString &soDefault =
>> "") const;
>> or
>> 2. const char* -> const std::string &
>> const; ->
>> or?
>> Best regards,
>> Dmitry
>> 05.01.2018 18:54, Kurt Schwehr пишет:
>> +1 for wrapping the old C code in some cleaner abstractions!
>> But +10 for switching to a from the ground up C++ JSON library unless there
>> are clear reasons for a core C library (I don't think there are)
>> If we are talking about this kind of code, there are several things that
>> have bugged me in general about GDAL for a long time.
>> * Passing char *psz yada all over the place in pure C++ code. A const
>> std::string is usually not a noticeable expense and is a lot safer
>> * CPLString when std::string will do just fine. And we can write free
>> functions to operate on strings. I'm generally bothered by subclassing of
>> std::string as CPLString. After reading large amounts of C++ code, I think
>> it adds more confusion than it ever helps over having clean free
>> functions. Interop and analysis with CPLString's is no fun.
>> https://stackoverflow.com/questions/6006860/why-should-one-not-derive-from-c-std-string-class
>> -kurt
>> On Fri, Jan 5, 2018 at 7:44 AM, Sean Gillies <sean at mapbox.com> <sean at mapbox.com> wrote:
>> Hi Dmitry,
>> I scanned the PR and it seems reasonable to me. I'm barely a C++
>> programmer at all and it's clear to me, more clear than before. That said,
>> I'm not a fan of wrapping things that could be replaced. Have you looked
>> into whether a more performant C++ JSON library could be used? I haven't
>> run the benchmarks, but json-c compares pretty poorly to others inhttps://github.com/miloyip/nativejson-benchmark.
>> On Wed, Jan 3, 2018 at 12:04 PM, Dmitry Baryshnikov <bishop.dev at gmail.com> <bishop.dev at gmail.com>
>> wrote:
>> Hi everybody,
>> Happy new year and lot of success in 2018!
>> I would like to discuss my pull request https://github.com/OSGeo/gdal/
>> pull/282
>> I created a thin wrapper around the json-c library which wide using in
>> GDAL.
>> This is C++ interface which hides C memory management and provides nice
>> API. The web or disk json documents reading chunk by chunk with progress
>> indication also added.
>> In future, the json-c can be easily switch to something other without
>> breaking the existing code.
>> The CPLJSONDocument/CPLJSONObject/CPLJSONArray usage examples can be
>> found in frmts/pds driver and c++ unit test in autotest/cpp/test_cpl.cpp.
>> Is this ready to merge into the trunk? Any objections?
>> Best regards,
>> Dmitry
>> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180109/ba71b665/attachment.html>
