[gdal-dev] SPOT7 DIMAP driver for tiled datasets has no lat/lon
Even Rouault even.rouault at spatialys.com
Sat Jan 13 07:15:55 PST 2018
Shawn,
the driver shouldn't likely report the geotransform in that case, but just the
RPC. You can try to warp it with gdalwarp -rpc
I've blindly pushed a untested fix in trunk so that the geotransform is not
reported in your case:
https://trac.osgeo.org/gdal/changeset/41264
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180113/334e9bc4/attachment-0001.html>
