[gdal-dev] Compile gdal with expat support on AWS Linux
Tobias Reinicke
ramotswa at gmail.com
Sat Jan 20 04:23:17 PST 2018
Yes that was it. Many thanks.
Toby
On 20 January 2018 at 12:08, Even Rouault <even.rouault at spatialys.com>
wrote:
> On samedi 20 janvier 2018 12:04:42 CET Tobias Reinicke wrote:
> > Hello,
> > I've been trying to get gdal compiled to be able to read GML files - but
> I
> > keep on getting expat / Xerces errors.
> > I am working on an AWS AMI that matches the AWS Lambda environment (as
> I'm
> > trying to get this working in Lambda really).(AMI:
> > amzn-ami-hvm-2017.03.1.20170812-x86_64-gp2 / amiId: ami-ebd02392)
> Tobias,
> If you did a first GDAL build without expat support, and then ran
> ./configure and make again, some files have not been recompiled, so do a
> "make clean" and build again.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180120/2f0ee994/attachment.html>
