[gdal-dev] AIG field types erroneously classified as GFT_String
Even Rouault
even.rouault at spatialys.com
Wed Jan 24 13:27:44 PST 2018
On mercredi 24 janvier 2018 19:10:13 CET Gregory, Matthew wrote:
> Hi all,
> I came across what I think is a bug on reading in VAT tables using the AIG
> driver. I have a raster attribute table that has fixed numeric types for
> some items and when using the GetTypeOfCol method (in Python), I'm getting
> back GFT_String (2) values. I think I can trace it to lines 463-480 in
> aigdataset.cpp. As it's looping through the fields, the type is set to
> GFT_String by default and only AVC_FT_BININT and AVC_FT_BINFLOAT are
> checked to possibly change type. It seems like there should also be these
> checks/conversions:
> AVC_FT_DATE -> GFT_Date(?)
> AVC_FT_FIXINT -> GFT_Integer
> AVC_FT_FIXNUM -> GFT_Real
> I could be missing the reasoning of why these types shouldn't crosswalk to
> the suggested GFT_* values, so I haven't submitted as a bug.
If you can submit a patch implemting the missing mappins, as well as some testing data, that
would be welcome
Best regards,
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180124/f88d4857/attachment.html>
