[gdal-dev] SPOT7 DIMAP driver for tiled datasets has no lat/lon
Gong, Shawn SGONG at mdacorporation.com
Tue Jan 30 08:00:25 PST 2018
Hi Even,
Your fix did remove the wrong georeferencing info. Thank you!
But I still need to run 'gdalwarp -rpc' to apply the georeferencing. It would be great if the GDAL driver can perform this extra step.
Thanks,
Shawn
Sent: January-18-18 2:42 PM
To: Gong, Shawn
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] SPOT7 DIMAP driver for tiled datasets has no lat/lon
On lundi 15 janvier 2018 21:05:59 CET Gong, Shawn wrote:
> The SPOT7 datasets are more than 2GB.
I've pushed another fix tested against the test dataset you provided to me.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180130/de852050/attachment.html>
