[gdal-dev] gdalwarp ERROR 6: PHOTOMETRIC=YCBCR requires a source raster with only 3 bands (RGB)
Stephen Woodbridge
stephenwoodbridge37 at gmail.com
Sun Jul 1 08:18:39 PDT 2018
Right, but the point 1 is the message says:
ie: requires a source raster with only 3 bands (RGB) and the source
raster has only 3 bands!
-dstalpha if I understand correctly is to create a alpha band in the
output file. So the error message is misleading at best.
Point 2 is how does one translate a utm to wgs84 using YCBCR and
generate an appropriate mask or alpha channel to hide the pixels that
are outside the transformed image. I suppose it needs to be done in
multiple steps of warp and translate in some specific order with
specific options but its not obvious how.
-Steve
On 7/1/2018 10:14 AM, Michael Smith wrote:
> Steve,
> Setting that alpha channel makes it 4 bands. RGB + alpha channel. Either remove the ycbcr or the alpha channel.
> Michael Smith
> Remote Sensing/GIS Center
> US Army Corps of Engineers
>> On Jul 1, 2018, at 10:07 AM, Stephen Woodbridge <stephenwoodbridge37 at gmail.com> wrote:
>> Hi all,
>> I'm trying to convert a utm jp2 file to a wgs84 tif file and getting "ERROR 6: PHOTOMETRIC=YCBCR requires a source raster with only 3 bands (RGB)" but the src file has only 3 RBG bands.
>> gdalwarp -t_srs EPSG:4326 -dstalpha -r bilinear -of GTiff -co BIGTIFF=YES -co TILED=YES -co COMPRESS=JPEG -co JPEG_QUALITY=90 -co PHOTOMETRIC=YCBCR '00010.jp2' 'tif/00010.tif'
>> The command works if I remove -dstalpha so it seems that the error message is erroneous and might need fixed. Regardless, I don't want the transformed image to have black around it, so how do I do that?
>> -Steve
>> # gdalinfo 00010.jp2
>> Driver: JP2OpenJPEG/JPEG-2000 driver based on OpenJPEG library
>> Files: 00010.jp2
>> 00010.jp2.aux.xml
>> Size is 340668, 65335
>> Coordinate System is:
>> PROJCS["UTM_Zone_38_Northern_Hemisphere",
>> GEOGCS["GCS_WGS_1984",
>> DATUM["WGS84",
>> SPHEROID["WGS84",6378137,298.257223563]],
>> PRIMEM["Greenwich",0],
>> UNIT["Degree",0.017453292519943295]],
>> PROJECTION["Transverse_Mercator"],
>> PARAMETER["latitude_of_origin",0],
>> PARAMETER["central_meridian",45],
>> PARAMETER["scale_factor",0.9996],
>> PARAMETER["false_easting",500000],
>> PARAMETER["false_northing",0],
>> UNIT["Meter",1]]
>> Origin = (265998.000000000000000,1848002.000000000000000)
>> Pixel Size = (3.000000000000000,-3.000000000000000)
>> Image Structure Metadata:
>> INTERLEAVE=PIXEL
>> Corner Coordinates:
>> Upper Left ( 265998.000, 1848002.000) ( 42d48'19.81"E, 16d42'11.25"N)
>> Lower Left ( 265998.000, 1651997.000) ( 42d49'28.30"E, 14d55'56.73"N)
>> Upper Right ( 1288002.000, 1848002.000) ( 52d22'11.02"E, 16d35' 0.58"N)
>> Lower Right ( 1288002.000, 1651997.000) ( 52d18'23.31"E, 14d49'33.87"N)
>> Center ( 777000.000, 1749999.500) ( 47d35' 9.06"E, 15d48'48.25"N)
>> Band 1 Block=1024x1024 Type=Byte, ColorInterp=Red
>> Overviews: 170334x32667, 85167x16333, 42583x8166, 21291x4083, 10645x2041
>> Overviews: arbitrary
>> COMPRESSION=JPEG2000
>> Band 2 Block=1024x1024 Type=Byte, ColorInterp=Green
>> Band 3 Block=1024x1024 Type=Byte, ColorInterp=Blue
>> This email has been checked for viruses by Avast antivirus software.
>> https://www.avast.com/antivirus
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
