[gdal-dev] [EXTERNAL] Re: FITS format not listed in gdalinfo --formats
Susan Borda
sborda at umich.edu
Thu Jul 5 11:40:22 PDT 2018
To build on Mac you can basically follow the Linux steps:
Download from http://download.osgeo.org/gdal/CURRENT/
cp or mv file to /usr/local (or wherever you'd like to install it)
gunzip
tar xvf
In my case I wanted to add in CFITSIO so I:
sudo ./configure --with-cfitsio
sudo make
sudo make install
It's running like a champ and parsing the *.fits headers!
Thanks for pointing me in the right direction!
-susan
On Thu, Jul 5, 2018 at 2:18 PM Jeff McKenna <jmckenna at gatewaygeomatics.com>
wrote:
> Trent, is it possible that you record all these steps and hints for
> compiling FITS support at https://trac.osgeo.org/gdal/wiki/BuildHints
> (i.e. create a new wiki page there and add a link to your build page in
> the "External Library Issues" section) That way the steps are recorded
> and easy to find (instead of lost in the email archives)
> I'm happy to add a Windows section for compiling FITS as well.
> thanks!
> -jeff
> On 2018-07-05 2:12 PM, Trent Hare wrote:
> > Susan,
> > Yes - the FITS format is supported in GDAL once compilation has
> > been linked to CFITSIO.
> > Note this driver is currently being enhanced to (1) better support FITS
> > files within GDAL and (2) the format FITS will have an extension added
> > to it, which allows more typical GIS map projection support. That branch
> > of GDAL is being worked on Chiara Marmo:
> > https://github.com/epn-vespa/gdal/tree/fits_driver
> > For Mac, I'm not sure this will work, but on Linux (Fedora and Ubuntu)
> > this should get you FITS support in GDAL (and also get QGIS with FITS
> also).
> > _In order to have QGIS working with FITS_
> > * install CFITSIO (Fedora : cfitsio-devel ; Ubuntu : libcfitsio-dev)
> > * install GDAL (Fedora : gdal-devel ; Ubuntu : libgdal-dev)
> > * install QGIS
> > *_Temporary workaround_: *
> > So a method Chiara created to test GDAL for FITS users is a simple
> > Python script which creates a GDAL VRT header pointing into the FITS
> > file. Once the VRT is created, any GDAL program can use it by pointing
> > at the VRT file (gdal_translate, QGIS, ArcMap, ...). Perhaps that is
> > worth a shot.
> > https://github.com/epn-vespa/fits2vrt
> > Lastly, once the FITS driver is updated we will try to support an
> > anaconda version of GDAL with CFITSIO pre-built for users (should help
> > Macs users too).
> > Good luck,
> > Trent
> > P.S. maybe a little un-tested *build help* (linux again - sorry).
> > Install CFITSIO
> > Clone/download the GDAL repo.
> > $ cd gdal/gdal
> > you have compiled there the 'fits-driver' branch, using
> > $ ./configure
> > In that same repo you have a config.log file.
> > If you grep cfitsio in config.log you must have (among others, and
> > depending on your distro)
> > EXTRA_INCLUDES='-I/usr/include/cfitsio '
> > LIBS='-lcrypto -lexpat -ljasper -ljpeg -lgeotiff -ltiff -lpng -lcfitsio
> > -lz -lpthread -lm -lrt -ldl -lpcre'
> > now
> > $ ./make
> > more: https://trac.osgeo.org/gdal/wiki/BuildingOnUnix
> > On Thu, Jul 5, 2018 at 9:59 AM Susan Borda <sborda at umich.edu
> > <mailto:sborda at umich.edu>> wrote:
> > Thanks Evan, I saw that mentioned in the formats list but I'm not
> > sure how to "build GDAL" with this library. I just downloaded GDAL
> > and it uses Python 3.6 but the version of CFITSIO I found uses
> > Python 2.x. I'm using a Mac but can easily run all of this on Linux
> > VM if need be.
> > -susan
> > On Thu, Jul 5, 2018 at 12:45 PM Even Rouault
> > <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com>>
> wrote:
> > On jeudi 5 juillet 2018 12:41:08 CEST Susan Borda wrote:
> > > Hi-
> > > I'm new to gdal and am trying to use gdalinfo to read a
> > *.fits file
> > > (astronomy files), specifically the header. When I list the
> > formats
> > > supported by gdalinfo, I'm only seeing FIT not FITS. Is FITS
> > no longer
> > > supported?
> > It is, but you must build GDAL against the CFITSIO library:
> > http://gdal.org/frmt_various.html#FITS
> > On Debian and derivatives, this is the libcfitsio-dev package.
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
> > Susan Borda
> > Data Workflows Specialist
> > Research Data Services
> > University of Michigan Libraries
> > 3175 Shapiro Library
> > 734-764-9134 | sborda at umich.edu <mailto:sborda at umich.edu>
> Jeff McKenna
> MapServer Consulting and Training Services
> https://gatewaygeomatics.com/
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Susan Borda
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180705/fc3a5cd2/attachment.html>
